Re: 340 utility pto questions
Posted by Owen Aaland on July 20, 2008 at 18:56:18 from (65.161.86.52):
In Reply to: 340 utility pto questions posted by BMD on July 20, 2008 at 12:28:06:
BMD said: (quoted from post at 12:28:06 07/20/08) Moving a pto asm. from a parts/nonworking 340 to a working 340 utility.The pto is the round style which I believe is the newer clutch style pto asm. Mounting and bolt up was no problem since the receiving tractor was set up for ipto.
How does on check and change the oil level in the pto unit? There appears to be a breather on the top center and a possible drain or level plug on the right side about 3/4 of the way down the unit. Did not see a drain plug under the unit, there maybe one just did not see it.
Does the unit take Hytran oil or 80/90 gear oil?
The pto currently appears to be stuck in the "engaged" position but once I find out if the asm has any oil in it and get it changed if it does I"ll move on to that issue next.
Thanks for any advise for it is greatly appreciated.
BMD
The PTO has it's own oil supply and uses Hy-Tran fluid. Fill it through the breather until it runs out the level check plug on the side.
When switching from the band/planetary style PTO to the disk clutch type you also need to change the PTO gears in the front of the clutch housing to keep the correct speed on the output shaft.
Today's Featured Article - Talk of the Town: Repairin a Gas Tank - by Staff. This interesting discussion is from the Tool Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
