Re: '45 M - hydraulics low?
Posted by billde on July 20, 2008 at 19:21:52 from (72.26.91.191):
In Reply to: Re: '45 M - hydraulics low? posted by Kevin Statz on July 20, 2008 at 18:22:01:
At the forward end of the cylinder body there appears to be a plug, top side of the cast piece. I think you have 2 way cylinders, they are set up as single acting.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
