Re: Timing H
Posted by Bob on July 21, 2008 at 12:31:13 from (69.178.228.68):
In Reply to: Timing H posted by GordoSD on July 21, 2008 at 12:26:03:
You are probably one crankshaft turn off, at the top of #1's exhaust stroke, rather than at TDC of it's compression stroke. Turn the engine one turn, then put the distributor back in the position you have it now.
