Re: Brake seal on Farmall H?
Posted by Guyzoo on July 21, 2008 at 15:50:36 from (207.179.184.57):
In Reply to: Brake seal on Farmall H? posted by Pairodox on July 19, 2008 at 17:38:38:
yep you need to change the seal and if you can't get the original seal just put two thinner seals one the lip inward, the other outward. I would also replace the oring if it is leaking. If you remove the carrier that the seal seats into don't forget to remove the big bull gear out of the way otherwise you will break the carrier... don,t ask how I learned that lol
hope this help and good luck
