Re: Brake drum on Farmall H
Posted by Pairodox on July 21, 2008 at 17:02:06 from (72.70.216.43):
In Reply to: Re: Brake drum on Farmall H posted by Coax on July 21, 2008 at 16:53:36:
You make it sound so easy. I've been trying the Blaster and WD40 routine without much luck. Will keep at it though. What about the cork washer that lies under the bolt - do you know of a source for that? Thanks for your help.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
