Re: H Starter Switch
Posted by 36 coupe on July 22, 2008 at 03:15:54 from (64.136.26.226):
In Reply to: H Starter Switch posted by Dave in CT on July 20, 2008 at 18:00:07:
Old starter switches usually have poor looking insulation material in them.A short circuit here is bad news.Changed mine for this reason, cost 7.00.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
