H Starter Switch
Posted by Dave in CT on July 20, 2008 at 18:00:07 from (69.182.52.83):
No-start on H - only has switch in between battery and starter. Jumped the starter post to + on the battery and it started right up. Voltmeter shows 13 with the push-pull switch pulled out (I'm sorry, I don't know what it's called) but drops to 0 when I press the starter switch. I've seen posts about disassembly and cleaning up the contacts on a starter switch. Might that be the next course of action? How hard is that to do? What's involved?
TIA
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
