Farmall Tractors Discussion Board
Re: Farmall C cylinder compression
Posted by Rick B. on December 20, 1998 at 06:24:02:
In Reply to: Farmall C cylinder compression posted by Danny Boudreaux on December 18, 1998 at 18:24:36:
Just be sure your valves are not way too tight before you pull the head off. Valves not closing will cause low compression.
Post a Followup
: Re: Re: Farmall C cylinder compression
