Re: 12v Generator Charge and Ballast Resistor
Posted by dave guest on July 25, 2008 at 20:25:35 from (4.229.117.157):
In Reply to: 12v Generator Charge and Ballast Resistor posted by Red Raider on July 25, 2008 at 19:53:35:
Resistor won't affect charging rate if you got it in the right place. Sounds like you do. Use voltmeter on batt and see if it is reading 13 or 14 volts, you are okay.
