If youre at 12 volts now you need to EITHER use a full true (some people call internally ballasted) 12 volt coil AND NO BALLAST or else a 6 volt coil with the external series voltage dropping (12 to 6) ballast resistor.
A 12 volt coil will have somewhere around 3 to 4 ohms primary resistance as measured between its lil + and - terminals while a 6 volt will be more like 1.25 to 2 ohms.
This ONLY affects the primary ignition circuit NOT the charging system
Once the ammeter is wired correct it would swing over to - discharge if its not running n you turn on lights and/or ignition then swing to + charge running if the charging system is okay. A battery polarity reversal requires an ammeter lead swap so it dont read bass ackwards.
For a troubleshootign procedure for non charging see my URL link in a post above
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro
... [Read Article]
