Re: farmall H stahls after 3 minutes
Posted by RustyFarmall on July 26, 2008 at 04:58:53 from (209.152.78.71):
In Reply to: farmall H stahls after 3 minutes posted by Rich ORourke on July 25, 2008 at 23:39:23:
First, get rid of that in-line fuel filter. If the screen is in place in the sediment bowl, as well as the screen in the fuel inlet fitting in the carb, there is no need for any additional filtering. Second, are you using the proper vented fuel cap? Is it working?
