Re: 12v Generator Charge and Ballast Resistor
Posted by John M on July 26, 2008 at 05:51:29 from (209.213.22.170):
In Reply to: 12v Generator Charge and Ballast Resistor posted by Red Raider on July 25, 2008 at 19:53:35:
The resistor is not in the right place. It should be in the line from the switch to the coil.Polarity wont matter if you polarized properly.
