Re: more 560d clutch problems
Posted by Brownie 450 on July 28, 2008 at 03:37:21 from (216.51.158.151):
In Reply to: more 560d clutch problems posted by Arkie on July 27, 2008 at 18:23:57:
Were the fingers on the pressure plate adjusted correctly when it was installed? Did the throwout lever engage the throwout bearing correctly?
