Posted by Arkie on July 27, 2008 at 18:23:57 from (69.29.166.17):
I hate to say it,but I"ve run into more clutch problems.I have the clutch springs toward pressure plate and have the pressure plate mated to the flywheel.Now I have the two halves of the tractor together and the clutch pedal travels back and forth with no tension on the pressure plate.When I brought the tractor halves together I had the pressure plate on the spline then the clutch plate.I bolted the pressure plate and the flywheel together from under the tractor.You guys have been great to help me and I appreciate it.Maybe if I get past this I can do the topend without pestering ya"ll to death.Thanks again!!
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
