Re: Hydraulic pump drive shaft on an H.
Posted by Wayne in MN on July 28, 2008 at 20:59:45 from (68.119.27.241):
In Reply to: Hydraulic pump drive shaft on an H. posted by Pairodox on July 28, 2008 at 16:44:03:
Are you removing the seal on the pump or on the pump drive coming out of the transmission?
Pump has to be removed to work with its seal; the drive coupler is removed from the transmission by locking the brakes, put the shifter in reverse, and use a pipe wrench or tool that fits the slot and turn lefty-loosey.
It is tight but will spin off when loosened.
