Re: Super M Transmission Seals
Posted by Chris NW Ind on July 29, 2008 at 06:49:15 from (64.136.26.226):
In Reply to: Re: Super M Transmission Seals posted by Chris NW Ind on July 29, 2008 at 06:45:45:
One comment: when and if you pull the entire input shaft assembly, you will be removing the front support for the upper transmission shaft. You may need to line it back up when reassembling. You can put the tractor in gear (maybe 4th) and/or you can work through the aforementioned belt pulley opening to line it up.
Chris B.
