Re: Super M Transmission Seals
Posted by Chris NW Ind on July 29, 2008 at 06:45:45 from (64.136.26.226):
In Reply to: Super M Transmission Seals posted by jimtrs on July 29, 2008 at 06:18:22:
Check out this link. I did a related job on my Super M a few months ago without splitting. Once you get the clutch shaft clear, you can pull out the entire input shaft assembly. Check out the bearings closely, particularly the pilot bearing. I believe you can get to that one if you remove the belt pulley/cover.
Chris B.
