Posted by ihman71 on July 30, 2008 at 13:42:33 from (216.51.206.22):
I got a 1486 that when going down hill at an idle the tractor like free rolls and wont hold back. if i open it up to around 1100 rpms it will hold back. also the steering and clutch and brakes dont work properly until i reach 1100 rpms. i put a new pump and gaskets in the center section behind the battery box on the left side of the tractor. that seemed to help a little but still not enough to work properly. the filter was changed and found some metal in it before the pump was changed. what else could the problem be? thanks for any help.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
