Posted by Chuck's Repair on July 30, 2008 at 17:46:28 from (162.40.106.186):
In Reply to: 1486 question posted by ihman71 on July 30, 2008 at 13:42:33:
You have an internal leak. Did you lose the sump check valve when you replced the pump? Is the o'ring around the steering relief valve leaking? Does this happen both in TA and direct drive? Does the transmission light come on when you step on the clutch? Is it on at low idle with the clutch engaged? Did you replace all gaskets and o'rings in the multiple control valve when you replaced the pump?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
