Re: Farmall 706 Question
Posted by Allan In NE on July 31, 2008 at 03:55:38 from (148.78.243.26):
In Reply to: Farmall 706 Question posted by Mike from Missouri on July 30, 2008 at 22:14:50:
My M was doing the same darned thing this spring; just about drove me nuts trying to figure it out.
Turns out the positive battery cable was shorting to ground with vibration just enough to kill 'er.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
