Posted by Mike from Missouri on July 30, 2008 at 22:14:50 from (216.106.26.196):
Have had the 706 for a month and been using it in the hay field to tedder, rake and to bale round and square bales. Also,use it to load and unload round bales. It has been running good. My question is this and it has just started this. It will start and run fine and then it will die. It has done this 3 times now in the past week. I mean there is nothing. No spark, no clicking nothing. I can take a screw driver and hit the starer celenoid and it will turn over and start, but as soon as I take the screw drive away it will die. I thought maybe the ignition switch was bad. I took it out and checked it out. It was ok. Put the switch back in and it fired right back up. The second time it did it I let it set for about 5 minutes and it fired back up. Same thing for the third time. Any suggestions?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
