Re: Farmall 706 Question
Posted by cental illinois on July 31, 2008 at 18:11:16 from (75.105.128.37):
In Reply to: Farmall 706 Question posted by Mike from Missouri on July 30, 2008 at 22:14:50:
I am not positive how a gas 706 is wired but your problem could be the starter solenoid, If the power wire from the solenoid comes from the starter. I have seen this on other tractors. Usually the solenoid will have the battery cable, a wire from the key switch, and a wire to the coil. All on three different posts.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
