Posted by Ted in NE on August 02, 2008 at 06:38:57 from (74.85.105.182):
In Reply to: TD9 injectors posted by FordsonMajorPat on August 02, 2008 at 05:08:33:
Pat If you got them to hold 400psi they will work fine. Did you clean the small hole where the spray comes out? This nozzle will not have the pattern of the late high press type. Not sure what kind of pop tester you have, most put to much fuel through. Try tapping the handle for a lesser fuel flow. Have rebulit many of this nozzle by lapping as you did, work fine.
