Posted by Ted in NE on August 02, 2008 at 18:09:57 from (74.85.105.182):
In Reply to: TD9 injectors posted by FordsonMajorPat on August 02, 2008 at 05:08:33:
Pat
The hole I was refering to is in the plate below the nozzle valve you cleaned. Can get some carbon build up over time. Clean with a tip cleaner of the right size. Valve adjustment is very important. Also check for stuck starting valves while you have the valve cover off.Push down on the cup that goes over the valve & spring retainer make sure they are coming all the way up. Can free them up if needed by removeing the rocker arm assembly & cup over the valve. Use penetrateing oil & work them up & down. If to sticky remove the spark plugs. You can spray the valve stem through the plug hole. Usually will free up just takes patience. Quick check for stuck starting valves, crank over with change over lever on diesel. Will crank faster on cyl with stuck starting valve.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
