Re: Wow! BE CAREFUL OUT THERE
Posted by MN Scott on August 03, 2008 at 13:40:30 from (206.9.216.33):
In Reply to: Wow! BE CAREFUL OUT THERE posted by Dan Bear Kelley on August 03, 2008 at 13:05:55:
If the chain is hooked to the drawbar there is no way the tractor can flip because the line of draft is below and behind the axle. If it would flip when hooked to the drawbar everytime you hooked a plow on and hit a tough place in the field it would flip.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
