I would NOT run straight Marvel mystery oil in the crankcase, but it would be O.K. to substitute one quart of engine oil for one quart of MMO or ATF. Doing so would probably not help very much though. The smoking at idle is most likely because of worn valve guides which need to be replaced. There are no valve seals unless someone has added them in an attempt to cure the worn guides. The fact that the compression raised by 10 pounds when you added oil to the cylinders tells me there is a piston ring problem also. Your engine is telling you that it is getting tired.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
