Posted by Jim R on August 03, 2008 at 21:07:32 from (209.181.187.225):
I recently acquired a 1950 Farmall "M". It runs good but it seems to be using a little oil and will smoke a little, only when idling, now and then. I did a compression test and all the cylinders had from 100 to 110 lbs. and adding a little oil to the cylinders only brought up the compression by 10 lbs., max. The tractor had been sitting for the winter before I bought it. I have run it for quite a few hours since I"ve had it. At one point it was spitting a little oil out the muffler but has seemed to have stopped that. What could be the problem? Could it be valve seals? I had a friend recommend to me, to put some Marvel Mystery oil in the crankcase, and run it for a while. What do you think? I hope some of you Farmall guys can give me some advise! Thanks for any help!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
