Put just a little lubricant into the cylinders and turn it over a few times so the cylinders are lubed well. Do a compression check and make sure it has good compression in each cylinder. After not being run that long, there is a 99% chance the carb will need to be taken off and rebuilt, YT sells carb kits. It would also be a good idea to check out the ignition system, make sure that it has a good blue spark, check the points and be sure they are clean. Another good thing to do would be just to take off the valve cover and make sure all the valves are free and don't stick when going up and down. Lube up the rockers and put the cover back on. Make sure that the sediment bowl, fuel tank and fuel line are clean and put some gas in the tank, put oil in the crankcase, check the antifreeze in the radiator, check the transmission oil and try starting it. Post here when you get it running or if you have any more questions.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
