Getting a Farmall H running again
Posted by mwhiting on August 04, 2008 at 18:53:45 from (66.59.144.242):
Hi all! I recently took over the family farm & want to get a Farmall H running again. I know it was last run in the 80's and ran reasonably well then. It's been parked indoors since (just wasn't needed). I have some uses for it, but before I try to start it again I'd like to know what you veterans would say needs to be done first. Apart from the obvious (new oil, new fluid - it has no fluid & maybe no oil), what should I be thinking about? The engine can be rotated OK with the cranking handle (that was tried once to see if it was seized, & it seemed to rotate fine). The starter doesn't work, so it was always started with a backwards pull with another tractor. I assumed I'd do the same now until I see if it runs well enough to put a new starter into it.
What suggestions do you have?
