Re: Getting a Farmall H running again
Posted by old on August 04, 2008 at 19:30:26 from (4.245.0.159):
In Reply to: Getting a Farmall H running again posted by mwhiting on August 04, 2008 at 18:53:45:
Fill the cylinder with tranny fluid. Then do things like new points condenser etc. Walk away for 2 or 3 days. Be sure you put the plug back in after the ATF. After a few days pull all the plugs and spin it over. Then take the oil plug and being careful take it part of the way out to see if it has water in the oil. If it does change the oil and then try to fire it up. You may need to rebuild the carb but I'd give it a try before I did a rebuild on it
