Re: Getting a Farmall H running again
Posted by El Toro on August 05, 2008 at 05:57:34 from (205.188.116.73):
In Reply to: Re: Getting a Farmall H running again posted by mwhiting on August 05, 2008 at 05:38:23:
Rub the ignition points with some 320 wet or dry until they're shiny. Put in fresh gas. Make sure there's no gum residue from the old gas being left in the tank. It make need cleaning
and the carburetor too if the tank is gummed up.
Put in new sparkplugs after turning the engine over. It the battery cables are cracked replace them with 00 cables if your tractor is still 6 volts. Clean all surfaces on the battery, at the starter and where the battery is grounded. Hal
