Re: Getting a Farmall H running again
Posted by mwhiting on August 05, 2008 at 05:38:23 from (66.59.144.242):
In Reply to: Re: Getting a Farmall H running again posted by GordoSD on August 04, 2008 at 20:20:44:
Thanks all this is great. I need a couple of points of clarification because I guess I'm not up on some of the terms or lingo.
-When you say clean the points, what do you mean?
- To check the spark, do I need any special tools or is there another way to do that?
- and one last one - here’s my naivety - what do you mean by taking the oil plug part way out to check for water in the oil? I guess I’m more used to modern engines that have a threaded oil plug - it’s either in or it’s own. I haven’t looked to see what the H uses for a plug.
Thanks
Michael
