Re: Noisy H
Posted by GordoSD on August 05, 2008 at 18:05:57 from (66.115.200.140):
In Reply to: Re: Noisy H posted by Chris NW Ind on August 05, 2008 at 16:50:24:
I removed the belly pump cover, and then the coupling shaft from the forward pto shaft. I started it up and it was louder than before.
There is an "upper shaft" with a coupling in there also. I assume that is from the engine/clutch/to input trasnsmission. Is there some troubleshooting for that upper shaft?
Gordo
