Re: Noisy H
Posted by Chris NW Ind on August 05, 2008 at 16:50:24 from (64.136.26.226):
In Reply to: Noisy H posted by GordoSD on August 05, 2008 at 13:57:53:
With the engine running and transmission in neutral, the input shaft and countershaft are turning and the belly pump if so equipped. Push in the clutch and all that stops. You can check the input shaft bearings by removing the belly pump shaft cover and the belt pully housing. You'll be able reach up and wiggle them around. If it's the pilot you ought to be able to tell from the belt pull opening. If countershaft, you'll have to pop the lid.
Chris B.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
