Re: SM charging problems
Posted by msb on August 06, 2008 at 21:51:16 from (67.236.181.63):
In Reply to: Re: SM charging problems posted by dave guest on August 06, 2008 at 21:37:48:
Battery is good . Will crank it for a few days until it gets run down. Just isn't getting charged. Haven't checked the voltage. Ampmeter does not show any charge. Turn the lights on and it shows discharge.Don't use the lights. No other electrical use.NAPA reg. New regulator works for a few months.Maybe its just gremlins. I seem to only have exotic problems. lol. p.s. Regulator is grounded good.
