You certain the system charges when a new regulator is installed? If it is it will push the ammeter needle far to the charge side with the engine running at speed. Also a voltmeter across the battery will indicate 7.0 - 7.5 volts.
If it's NOT charging, temporarily bypass the regulator by first grounding "F" terminal at the regulator. Then with the engine running at speed jumper the GEN and BAT terminals at the regulator.
If it now charges the regulator is no good. However if still no charge, either generator is bad or there's an open circuit in the generator/regulator/ammeter wiring.
Also: Have you polarized the generator? (Momentarily jumper the reg's GEN and BAT terminals with the engine shut down).
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
