Re: Disc Brakes for Super M
Posted by GordoSD on August 07, 2008 at 08:20:29 from (66.115.200.140):
In Reply to: Disc Brakes for Super M posted by CHIEFEAVES on August 07, 2008 at 02:59:11:
The design of those brakes, using no rotor, but instead the two "outer surfaces" Does not allow any replacement of the "rotor" when it is worn too thin. Your inner and outer surfaces have most likely been worn down. The only solution is to take the outer cases in to a shop and have them planed down about1/10 of an inch.
Do one side and check it out. Take off more if you're not satisfied. Then do the other side the same.
You could also have the shop chuck that case in a lathe and just ever so slightly score that shiny surface.
Gordo
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
