Posted by AaronP on August 07, 2008 at 08:49:56 from (132.13.10.26):
Howdy, I am looking at buying a Farmall H for $600 tractor has new paint and the guy says everything is in good working order. I am not sure as to the year. do ya'll think its worth messing with I do plan to use it as a tractor and not a show piece. What would I need to look for when I go down to check it out? Anyhow as an aside, is there a square baler this thing can handel? ( I know nothing about tractors or impliments I will be looking to start hay production for personal use)Also what size cutter/conditioner could I run behind it. And any advice you have to someone as new as me would be awsome.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
