Posted by Janicholson on August 07, 2008 at 09:15:27 from (199.17.6.68):
In Reply to: Farmall H prices posted by AaronP on August 07, 2008 at 08:49:56:
If it runs and is as described it is a steal. It will handle a bailer fine. (you will need a solid instruction period on it with a experienced Non-live PTO driver, to be sure and safe) Even if it needs some help, it is a great buy. JimN
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
