Re: OT dialup internet and electric fence (kinda long)
Posted by charles todd on August 08, 2008 at 21:29:38 from (205.242.95.131):
In Reply to: OT dialup internet and electric fence (kinda long) posted by Haas on August 08, 2008 at 18:33:48:
The electric fence and the phone ground on the same plane. The "tick" means you have a high-power, pulsed charger. Most phone cable is non-shielded. Sounds like your fence charger, telephone J-box, and power distribution are very close together. RF interference seems evident. You mention using some "shielded" cable/wire. When using shielded cable you only ground ONE END, shield in the field or the end of the line, not at the source.
Hope this helps,
Charles
