Re: Smoking Tractor
Posted by scott rukke on August 08, 2008 at 23:36:10 from (67.183.230.71):
In Reply to: Smoking Tractor posted by Wayne Mo on August 08, 2008 at 21:15:00:
Guessing the valves. To test whether it's the valves or rings, do a compression check and then put a teaspoon of motor oil in each cylinder and do another compression check. If the compression comes up considerably it's the rings, if it doesn't come up it's the valves.
