Smoking Tractor
Posted by Wayne Mo on August 08, 2008 at 21:15:00 from (207.69.139.146):
I picked up a late model H that starts easily with a hand crank and runs great but smokes. It smokes more when you rev it up and then back it off. I will read the plugs tomorrow and run a compression check. I might put air pressure in the spark plug hole and listen at the intake and exhaust for air flow.
Any ideas as to what is most likely the problem? Any ideas on what I could check out? I am wondering if a head valve job will fix it.
