Posted by TX656 on August 09, 2008 at 05:57:18 from (71.48.166.206):
I had a flat...because a wheel clamp rubbed a hole through the bump in the wheel that is supposed to stop the fore/aft slippage! My fault, I had noticed some shine on the wheel previously. Tires are 13.6x38.
After the tire was off I was able to determine I had play both side to side AND front to back between the clamps and the wheel. All bolts/nuts bottomed out; no room to tighten any of them further.
The"code" stamped on the wheel is W2b 1238 (with a date code of 12/59?) Too early for a 656 unless IH just had warehouses full of this stuff? The wheel part # in the book looks like it s/b 392 415 R1. (The part # on the Rim is 363014 R5 F1.)
I removed quite an assortment of wheel clamps (only one of which looked like it might have had the proper spacing to secure the wheel from slipping front to back. When in Wisconsin last year I picked up a wheel clamp because I knew I was missing one (never put it on). The clamp I got there (part #380870R1) supposedly was off of a 656. That clamp is the one at the right in both of the pictures.
The book says:
381 728 R1 Clamp, Rear Wheel Rim Adjustable -12-
381 726 R1 Clamp, Rear Wheel Rim Fixed -4-
Does that mean I s/b using 6 adjustable clamps per wheel and 2 fixed clamps per wheel? (Is the clamp at the far left an example of an adjustable clamp because it has up/down play in the bolt hole?)
I'm going to flip the wheel around to run in the opposite direction and therefore use the unmolested wheel bumps with the new clamps and keep my spacing the same. Should I go with new IH clamps (if available) or is this a very unusual situation and the ones I'd get from a salvage yard would probably work great? The one from Wisconsin didn't seem to have any wear but that is my only experience.
(Also, what are the nuts with the hoops on the end for. I don't like them; hard to remove.) The other wheel/rim have the same mongrel setup so I can't reference it as an example. As always, thanks for your help.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
