Re: 656 wheel/rim/clamp problem (pics)
Posted by Hugh MacKay on August 10, 2008 at 07:39:25 from (209.226.247.143):
In Reply to: 656 wheel/rim/clamp problem (pics) posted by TX656 on August 09, 2008 at 05:57:18:
TX656: If the tractor was run any length of time with one clamp missing, the rim will be out of shape, and that alone would make it difficult to keep the wheel tight. Even though not all those clamps are 656 specific, if they are not excessively worn or cracked they should tighten and keep the wheel tight. A loose wheel is what caused your wear. You do have to have the proper clamps at the rim bumps.
