Re: OT: Finally figured out the real reason
Posted by charles todd on August 10, 2008 at 11:26:34 from (205.242.95.131):
In Reply to: OT: Finally figured out the real reason posted by Hugh MacKay on August 08, 2008 at 03:59:50:
The Olds Toronado is an interesting milestone in automotive engineering. I think it was in 1966 that they first offered it as a FWD. The transmission was a TH400 split in half and coupled together, side-by-side with a chain drive... I have never seen one in person, but a 425 BB with a modified TH400 stuffed under the hood must be a sight!
Charles
