Belly pump on H
Posted by Pairodox on August 10, 2008 at 17:30:13 from (72.70.210.55):
I've noticed that my belly pump is leaking. From the bottom if you look at the thing while on your back ... and from the 'front' if you look at the thing from the observation port. Are there gaskets that need to be replaced here? I'm guessing I need to remove the entire pump. Is that hard? If I disconnect the hydraulic drive shaft and (3) supply lines do I then simply remove the bolts on the bottom? Can't be that simple.
