Re: Belly pump on H
Posted by Cub n M in OR on August 11, 2008 at 11:41:22 from (4.178.174.126):
In Reply to: Belly pump on H posted by Pairodox on August 10, 2008 at 17:30:13:
I just pulled the belly pump out of my M. I used the threaded rod trick. it worked fine, but it was slow. If I do it again, I will still use the threaded rod for stability, then just put some blocks under it while taking out the last two bolts, then pull the blocks, and lower it by hand, it was heavy, but not so bad I wouldn't feel comfortable lowering it by hand. Your results may vary.
Ben
