Posted by Andrew Kappers on August 11, 2008 at 14:14:10 from (207.109.213.2):
In Reply to: Super M??? posted by Skyhawk Greg on August 11, 2008 at 08:58:41:
Easy way to tell between the m and super m is that the super m has the disk brakes like the later number series tractors while the m had the band brakes with a flat surfaces shround covering the brakes. According to the brakes in the picture, its an m.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
