Posted by GordoSD on August 12, 2008 at 16:22:34 from (66.115.200.140):
I guess I was too lucky the other day when the Hfired up, lights generator, everything worked after engine rebuild and complete new wiring harnesses. So on the the SMTA. New wiring end to end. Battery charged, tested at IH shop, new ground oo cable, new cable to switch/starter. Pulled the rod, notthing , no click even. Pulled ignition switch out ammeter shows 5 amp negative. It moves to the right slightly when pulling the start rod. Voltage at starter switch is 6.5 Turned the engine by hand, it's loose. Pulled the plugs just to lighten the load. Still won't turn over. Is there some voltage. amperage test I can do to see what the problem is? I did ground the system to the battery box lid because of cable issues.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
