Re: SMTA WOn't turn over.
Posted by Bob M on August 12, 2008 at 17:20:34 from (74.74.140.97):
In Reply to: SMTA WOn't turn over. posted by GordoSD on August 12, 2008 at 16:22:34:
I agree with Rusty: Most likely it's a worn out saddle switch. Or possibly a dirty/badly worn copper button terminal on the starter beneath the saddle switch.
You might try removing the saddle switch then using a jumper cable to feed the starter power terminal directly from the ungrounded battery terminal (expect a spark!). If the starter engages you've found the problem. (It's fairly common BTW...)
